Date/Time: Thu, 16 Jan 2025 09:37:34 +0000
Weekly OHLC
View Count: 1173
[2017-10-25 12:15:43] |
User78442 - Posts: 260 |
My charts on 6E are not showing the weekly close properly (using WOHLC Study) I've tried changing the session times but I still get the same - The settings are the same on Gold but it works fine on all my other charts - Any ideas (charts enc.)
6EZ7 240 Min #13 2017-10-25 13_06_17.839.png / V - Attached On 2017-10-25 12:15:06 UTC - Size: 124.34 KB - 349 views GGCZ7 240 Min #13 2017-10-25 13_08_40.836.png / V - Attached On 2017-10-25 12:15:18 UTC - Size: 106.01 KB - 308 views |
[2017-10-25 18:40:53] |
We need a couple of days to look into this.
[2017-10-26 23:48:49] |
This study should never have been added. It was added by a former developer and not properly implemented. It is being removed in the next release permanently. Use the Period OHLC-Variable Period study instead: Previous/Period OHLC-Variable Period It has all of the capabilities you will need. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
