Date/Time: Thu, 16 Jan 2025 08:49:19 +0000
Chart Data Differ
View Count: 838
[2017-10-25 11:39:54]
User172040 - Posts: 70
Hi, I copied a chart from my chartbook. It's a 4000 'numbers per trade per bar' CL chart. On the 1 chart I show normal candlesticks. On the copy I opt for a numbers bar chart. However, the candle formation for 2 differ. It should be the exact same copy right? My chart settings in both seem to be exact so I'm not sure where I go wrong? Please see attached
imageNumbers Bar View.PNG / V - Attached On 2017-10-25 11:38:34 UTC - Size: 70.24 KB - 306 views
imageNumbers Bar Chart Settings.PNG / V - Attached On 2017-10-25 11:38:48 UTC - Size: 41.51 KB - 314 views
imageCandlestick View.PNG / V - Attached On 2017-10-25 11:38:54 UTC - Size: 52.89 KB - 281 views
imageCandlestick Chart Settings.PNG / V - Attached On 2017-10-25 11:39:01 UTC - Size: 41.73 KB - 289 views
[2017-10-25 18:49:02]
What is the difference? Be 100% precise and just give us one small example. And let us know if these charts are from different instances of Sierra Chart.
When posting an image of a chart only use this method here:
There is no need to also post the Chart Settings generally. There are many settings which are still not even visible.
Date Time Of Last Edit: 2017-10-25 18:49:30
