Date/Time: Thu, 16 Jan 2025 09:00:59 +0000
Erase all drawings
View Count: 577
[2017-10-25 01:43:24] |
User472677 - Posts: 356 |
Is there a command to erase all drawings?
[2017-10-25 01:49:44] |
Refer to: Chart Drawing Tools: Erasing Chart Drawings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
