Date/Time: Thu, 16 Jan 2025 07:54:42 +0000
DATA
View Count: 656
[2017-10-24 18:30:07] |
Marián Motúz - Posts: 2 |
I bought real time data today(package 5). My data are be late for 10 minutes. In the real time works only TICK indicator. How do I get the right real time data? BR |
Private File |
[2017-10-24 18:36:02] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-24 18:49:58] |
NQZ17 see the attachment in the first email... |
[2017-10-24 23:14:02] |
In regards to real-time futures data, read through this page: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Re-through that page in its entirety and make sure you fully understand the subject. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
