Date/Time: Fri, 22 Nov 2024 16:15:05 +0000
CLEAR TRADE SIMULATIONS ORDERS AND DATA
View Count: 2681
[2017-10-24 17:04:05] |
User63769 - Posts: 35 |
The command "CLEAR TRADE SIMULATIONS ORDERS AND DATA" clears ALL simulation accounts at the same time. It would be useful to be able to manually clear a single simulation account at a time. [There is a work-around by stopping a replay of the chosen simulation account and upon restarting, choose to delete data from the given account, however this is often not efficient.] |
[2017-10-24 18:13:35] |
You can do this by following the instructions here: Trade Activity Log: Clearing Trade Activity Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-24 20:22:46] |
In my Trade Activity Log, I don't have "Simulated" as a choice in the second drop-down menu, only "All Internal Order IDs" and a lot of numbers.
Trade Activity Log.PNG / V - Attached On 2017-10-24 20:20:52 UTC - Size: 12.69 KB - 300 views Attachment Deleted. |
[2017-10-24 23:58:41] |
We apologize. The documentation was out of date. We have fully updated it now: Trade Activity Log: Clearing Trade Activity Data You will need to reload the page. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-02 15:58:57] |
User630447 - Posts: 10 |
How do I change the default background shading and text color of the window header that shows the chart symbol, contract information, etc? It's defaulted to a light gray font on a light blue background and I can barely see it. I think the settings are in "Global Settings / Graphic Settings - Global" but there are about 100 settings and I can't seem to locate it. I believe there is one for the text color and one for the tab background color? I attached an image of it if that is helpful. Thank you. |
Window Title Header Text Color and Background Shade.JPG / V - Attached On 2024-10-02 15:58:12 UTC - Size: 220.6 KB - 31 views |
[2024-10-02 19:18:20] |
John - SC Support - Posts: 36219 |
That is an operating system setting. It is not controlled through Sierra Chart.
