Date/Time: Thu, 16 Jan 2025 08:56:37 +0000
Do "not" send orders to trading service. Does this make the live chart fail to send or
View Count: 1007
[2017-10-24 15:05:28] |
Glenn Infinity - Posts: 103 |
I have a 3 min chart up running and set to send live entries to the Trading service. I also have a Renko chart running and set on Do "not" send orders to trading service. Does this make the live chart fail to send orders? Bottom line is can I run two charts simultaneously. One firing live trades and the other not. I'm trying to use the renko chart as a take one off as the 3 min chart doesn't do that well. |
[2017-10-24 18:08:26] |
Does this make the live chart fail to send orders? No this is not the problem.We are really not understanding what you are trying to say here. If you are having some kind of problem with the sending of orders, look at the Trade >> Trade Service Log for additional details: Trading Information Windows: Trade Service Log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-24 18:08:58
[2017-10-24 18:13:35] |
what i think the customer was asking is, if "do not send orders to trading service" is enabled will it block orders from being sent?
[2017-10-25 17:43:09] |
They are referring to this Input setting: Automated Trading Management: SendOrdersToTradeService It is specific to individual studies. It is not a global setting. They really need to check the Trade >> Trade Service Log for whatever the issue is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-25 17:44:00
