Date/Time: Sun, 24 Nov 2024 02:52:40 +0000
Deleting files from Data folder
View Count: 1520
[2013-09-10 21:12:51] |
bullyboy - Posts: 11 |
I have many old quarterly futures charts in my Sierra Data file. I want to delete them before I back-up the data file and gain a lot of hardrive space. Can I just open the data file, right click on the old files and hit delete or do I need to do more to eliminate them from my computer. Thanks for your help. |
[2013-09-10 22:51:50] |
Yes. This is the right way to do it. Here are the detailed instructions for this: https://www.sierrachart.com/index.php?l=doc/doc_ChartDataFiles.html#DeletingCharts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-10 22:52:25
