Date/Time: Thu, 16 Jan 2025 08:11:47 +0000
Renaming Instances
View Count: 1037
[2017-10-24 13:40:18] |
User12167 - Posts: 16 |
Is it possible to rename the main and child instances? The purpose of this is to be able to identify the different instances more quickly via the windows task bar. Currently they all display "Sierra Chart 1626, Sierra Chart #2, etc". It would be good if the user can set a custom, shorter title e.g. DOMs, HTF, etc
[2017-10-24 19:16:33] |
Yes. Refer to this particular setting: General Settings Window: Custom Title Bar Name (Global Settings >> General Settings >> GUI >> Application GUI) You can also customize the icon of Sierra Chart by putting a Program.ico icon file into the main Sierra Chart program folder. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
