Date/Time: Thu, 16 Jan 2025 09:54:24 +0000
Candlestick bars not drawing bodies
View Count: 1765
[2017-10-23 23:16:06] |
User495024 - Posts: 9 |
On my historical data charts, the candlestick bars are drawing just the highs and lows, the bodies are being ignored. Does any one know why or how to fix? Thanks.
[2017-10-24 00:04:31] |
On that chart go to Chart >>Graph Draw Types. What is it set to? Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-24 00:13:16] |
It is set to Candlestick Bars. I updated to the newest version of Sierra Chart last night and they were drawing like this today. I can send a screenshot, if needed. As I said, its only doing this on the Historical Data charts.
[2017-10-24 02:20:41] |
[2017-10-24 03:35:10] |
http://www.sierrachart.com/image.php?Image=1508816049352.png
[2017-10-24 04:54:08] |
Go to Window >> Current Quote Window. What are the Daily High and Low values?
[2017-10-24 11:53:40] |
High: 6122.24 Low: 6061.08 Since it's a new day, it looks like yesterday's bar is printing with its body, while today's bar isn't: http://www.sierrachart.com/image.php?Image=1508845999809.png |
[2017-10-24 13:15:36] |
Actually, we were mistaken. We want to know the Daily Open and Daily Close values in the Window >> Current Quote Window.
[2017-10-24 13:20:11] |
Open: 6122.24 Close: 6067.83 |
[2017-10-24 14:15:44] |
This is very unusual. Go to Window >> Chart Values Window. What do you see for the Open and Close there?
[2017-10-25 01:51:03] |
Here's today's bar at end of day: http://www.sierrachart.com/image.php?Image=1508896193460.png |
[2017-10-25 17:48:46] |
We can see the Open price for the bar is 0 and that is the problem. You should also see a zero for Open in Window >> Current Quote Window. Confirm if you do. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings After the update, re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-26 18:53:27] |
Yes, I saw zero as well. I updated the symbol settings and it seems to have worked for all but one of the historical charts - The Daily chart. If I change it to a 2 Day chart, it looks fine.
