Date/Time: Thu, 16 Jan 2025 08:05:26 +0000
evening session timeframe lost
View Count: 911
[2017-10-23 21:19:17]
User472677 - Posts: 356
I have a large number of charts in a layout. All charts were set to use global settings and provided data for the evening session.
Now something has happened, perhaps a setting I accidently changed, none of the charts have evening data. Under chart settings for each chart, now the evening session is unchecked.
How do I revert all charts in this layout so that all charts show the evening session?
[2017-10-24 03:33:15]
ertrader - Posts: 681
Same thing happened to me. I just reset them but I only had about 16 charts.
[2017-10-24 04:45:33]
You need to enable Chart >> Chart Settings >>Session Times >> Use Evening Session for each chart.
If you normally want this option enabled, then do this globally for the symbol or symbol pattern in Global Symbol Settings:
