Date/Time: Thu, 16 Jan 2025 07:39:23 +0000
Sierra Execution Alerts
View Count: 1050
[2017-10-23 18:04:46] |
MichaelPPTF - Posts: 69 |
Hi there, These are the execution alerts that I have set in the General Trade Settings and I have set it to send email to a specific address. "New Order Sierra Chart Email Alerts <alerts@sierrachart.com> 10:35 AM (26 minutes ago) to me OrderPlaced | 2017-10-23 10:35:33" The subject line reads "New Order" which is my custom name for this alert. However, it lacks what symbol and what price my order is fill at... I wonder if there's a way to put more detail in the alert email. Thanks, Michael |
[2017-10-23 20:44:27] |
Do you have Global Settings >> General Settings >> Alerts >>User Defined Name Only in Alert Message enabled for the particular Alert Number you are using? Otherwise, there should be full detail including the trading account number. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-23 20:47:04] |
Yes I do have that enabled - Now got rid of it. Thanks for your quick reply. |
