Date/Time: Thu, 16 Jan 2025 08:12:56 +0000
daily statistical range and pivot points
View Count: 964
[2017-10-23 15:55:20] |
User780238 - Posts: 45 |
Hello, How do I have my daily r2, r1, PP, s1, s2 (normal daily statistical range) for an instrument displayed onto my 15M chart for that instrument and how do I move all of my pivot points lines on my D, W and M charts to the 15M charts for that instrument. Thank you |
[2017-10-23 17:10:57] |
You just need to use the following studies directly on the 15 minute chart: https://www.sierrachart.com/index.php?page=doc/PivotPoints.html#s87 https://www.sierrachart.com/index.php?page=doc/PivotPoints.html#s223 And configure them as required. Also refer to: Study/Price Overlay Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-23 17:11:47
