Date/Time: Thu, 16 Jan 2025 07:50:38 +0000
Warning started displaying after update to v1625
View Count: 888
[2017-10-23 14:51:27]
GiantAvocado - Posts: 67
Can you tell me what this warning means? This is showing up on my main instance v.1626 and the DTC client v.1625;
Software version: 1625 | 2017-10-23 10:45:29
Usage end date: 2018-01-10 | 2017-10-23 10:45:29
Enabled for: Advanced Features. | 2017-10-23 10:45:29
Enabled for: Advanced Features 2. | 2017-10-23 10:45:29
Enabled for: Sierra Chart Historical Data Service. | 2017-10-23 10:45:29
Allow Support for Sierra Chart Data Feeds is enabled. | 2017-10-23 10:45:29
Current selected Data/Trading service: DTC - Sub Instance | 2017-10-23 10:45:29
Chart Update Interval: 500 | 2017-10-23 10:45:29
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-10-23 10:45:29
2017-10-23 10:45:29 Local computer time | 2017-10-23 10:45:29
2017-10-23 14:45:29 Local computer time in UTC | 2017-10-23 10:45:29
2017-10-23 10:45:29 Local computer time in SC Time Zone | 2017-10-23 10:45:29
2017-10-23 13:31:08 Server time in UTC | 2017-10-23 10:45:29
Local computer UTC time and Server UTC time difference: 1 seconds. | 2017-10-23 10:45:29
Program path: C:\SierraChart\ | 2017-10-23 10:45:29
Data Files path: C:\SierraChart\Data\ | 2017-10-23 10:45:29
OS Version Number: 6.3 | 2017-10-23 10:45:29
Locale Setting: C | 2017-10-23 10:45:29
Warning: c_StreamBuffer::Expand called with NumBytes=65315595 | 2017-10-23 10:46:22 *
[2017-10-23 16:23:19]
This indicates a large memory allocation. This was added to debug the problem you had with the exception and abnormal shutdown related to Spreadsheets.
The way that spreadsheets will be saved will change, to not have these large memory allocations.
