Date/Time: Thu, 16 Jan 2025 16:59:41 +0000
Trade Window Positioning When Attached
View Count: 987
[2017-10-23 14:51:15] |
TSiSVT - Posts: 21 |
Is there a way, or could it be implemented, to be able move the trade window down the chart. Currently it's set at the top right of the chart. My issue is that I use a 49" 4k which puts it out of my direct line of sight to my chart dom. I would like to be able to position it half way down (while attached) or when using a smaller monitor position it at the bottom right. Either a high, mid , or low option or an offset option would be great.
[2017-11-15 13:48:02] |
Any input regarding this?
[2017-11-16 17:53:54] |
No, this is not supported.
