Date/Time: Thu, 16 Jan 2025 07:51:22 +0000
DAX
View Count: 1732
[2017-10-23 13:12:18] |
spfcbrasil - Posts: 6 |
Hi, I need sierra chart only to get data from DAX german indice. How much it will cost for a monthly payment the platform + data from dax ? |
[2017-10-24 04:57:44] |
The least expensive way would be to use the GER30 CFD symbol included with this service: Sierra Chart Real Time and Historical Forex and CFD Data Service You just need to use Sierra Chart Service package 3: Description of Service Packages and Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-24 12:16:18] |
Hi, thank you very much for your reply. I just forgot to say I need to be able to use ( and get the data ) for Volume Profile and TPO . Thanks again |
[2017-10-24 19:27:21] |
In this case you will need the EUREX futures data. You will need to use Sierra Chart Service package 3: Description of Service Packages and Pricing And you will need to use the Sierra Chart Exchange Data Feed and activate the EUREX exchange. You can find pricing here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
