Date/Time: Sun, 24 Nov 2024 03:01:10 +0000
How to get rid of Chart values and Current Quote windows
View Count: 1225
[2013-09-10 20:10:48] |
JP - Posts: 24 |
I am not sure if I am missing something but everytime I detach a chart, the Chart values and Current Quote windows open up for it. Even if I close these pop up windows they show up a few seconds later when I click on the detached chart. Is there a way to avoid having these Chart values and Current Quote windows show up for detached charts? Thank you JP |
[2013-09-10 23:03:57] |
This does not make sense and we cannot reproduce the problem. If you close those windows they should not reappear. We see no reason why they would. However, check to make sure this option is unchecked: Global Settings >> Tool Settings >> Chart Values >> Show Hide Tool Values Window when Tool Activated/Deactivated Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
