Date/Time: Thu, 16 Jan 2025 07:58:26 +0000
Suggestion in Pre-release Numbering
View Count: 1154
[2017-10-23 11:30:00]
Xfanman1 - Posts: 320
It seems that Pre-release versions of SC often get incrementental updates before they are rolled into the next main release or another whole number Pre-release version. Is it possible to append the whole number in a Pre-release with an alpha character so we can see if we have in fact gotten the most recent changes? As an example, Pre-release 1626, 1626a, 1626b, 1627 and so on?
I often see comments made to people awaiting changes or fixes (myself included) to download the latest Pre-release because you just updated the code even though I see that pre-release number may not have changed for days. This isn’t critical of course but just a suggestion (if possible) to help clear up some minor confusion among the user base.
Thanks much....Scott
Date Time Of Last Edit: 2017-10-23 11:41:14
[2017-10-23 17:15:26]
What we really need to do is always increment the version number even with small changes. Sometimes we just want to avoid that. But we should do that.
[2017-10-23 17:21:20]
That certainly works too, I just thought you'd still be able to use whole numbers for your regular version changes and append the PreRelease's until you were ready for a regular release update.
