Date/Time: Mon, 27 Jan 2025 21:48:07 +0000
Extanding Rectangle Text Labels
View Count: 1146
[2017-10-22 07:06:46]
Dom7364 - Posts: 257
How do you define Extanding Rectangle Text Labels instead of actual numerical values?
Txs
[2017-10-22 20:15:38]
You can set text on a Rectangle drawing and this is documented here:
Chart Drawing Tools: Modify Text
[2017-10-23 06:19:02]
Thank you but I meant dynamically and automatically, just as the values are being displayed to the right of the extending rectangle
