Date/Time: Thu, 16 Jan 2025 07:05:22 +0000
Yearly or higher chart - Blank Screen?
View Count: 819
[2017-10-22 02:12:38] |
User9415867 - Posts: 38 |
Does anyone know how to display the yearly bar for an instrument? When I download a historical chart and try to display a yearly bar or have an indicator calculate based on it, the screen is blank? Can a longer chart than yearly be displayed?
[2017-10-22 02:23:37] |
You should see at least one bar in this case. What is the symbol of the chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
