Date/Time: Thu, 16 Jan 2025 12:17:10 +0000
1626 a) Bar numbering b) Renko on delta volume
View Count: 2019
[2017-10-22 01:30:26] |
marty_nv - Posts: 85 |
Thank you for wonderful charts. a) Attachment one shows new Bar Numbering study; Settings have not changed for me, but bar numbers in my windows7 OS don't seem to locate at bottom of screen, even if that parameter is set to "yes", even won't put bar numbers in colored background now, maybe I have missed something new in 1626. Older versions I have no problem with. b) I have had to go back to old SC versions because I can no longer construct Enhanced Renko bars on delta volume chart style (or other chart styles). Since Renko study has been removed; the new revised renko chart styles are innovative, I occasionally used them until 1626. |
Pat 171021-1 Bar numbering Issue.png / V - Attached On 2017-10-22 01:27:53 UTC - Size: 48.13 KB - 388 views |
[2017-10-22 01:52:23] |
1. The Bar Numbering study has been improved upon performance wise, and the ability to locate the numbers at the bottom of the chart will be supported in the next release. 2. We have 100% discontinued all support for the old Renko studies. Although they are still listed in Analysis >> Studies >> Add Custom Study. Just make sure the Graph Draw Type setting for them is set to the one of the "Renko" type types and they should still work as previously. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-06 07:17:08
[2017-10-22 20:09:52] |
Thanks, Perfect charts. I'm looking forward to 1627 bar numbering (for fractal studies). I'm in older version until then.
[2017-10-22 20:52:02] |
On a different subject: Point and Figure charts now use box size in ticks. Can Kagi Charts have an option for Reversal amount in ticks? (see attachment) |
Pat 171022-1 Kagi fixed value.png / V - Attached On 2017-10-22 20:50:02 UTC - Size: 65.25 KB - 303 views |
[2017-10-23 07:14:54] |
Not critical, 1627 doesn't allow "Use Transparent Background" functionality, though listed as an option in Bar numbering study. Also noted that to float "bar numbering" on top requires it to read first--last study of stack. |
[2017-11-06 07:16:19] |
Not critical, 1627 doesn't allow "Use Transparent Background" functionality, though listed as an option in Bar numbering study. We will remove this.Can Kagi Charts have an option for Reversal amount in ticks? (see attachment) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
