Date/Time: Thu, 16 Jan 2025 07:03:04 +0000
Bitcoin New Weekly Candle is wrong
View Count: 1607
[2017-10-22 00:09:42]
N!co - Posts: 140
Bitcoin, just started a new week
please see screenshot,coompair the weekly and daily chart, and notice that the weekly candle is wrong, it already shows highs and lows
thx
imagewekly_candle_wrong_at_start_week.png / V - Attached On 2017-10-22 00:09:27 UTC - Size: 92.74 KB - 298 views
[2017-10-22 00:29:43]
You need to tell us exactly what is wrong.
Otherwise we are declining this support request. We are not going to go through an immense a lot of work to try to understand what you are saying. You need to be 110% precise with us.
[2017-10-22 00:44:59]
N!co - Posts: 140
ok,
please look at the Last candle in both charts (screenshot above)
left the weekly chart and on the right the daily chart
because the daily just started a new day, the candle has (as expected) NO wicks
BUT on the left side, the weekly chart , that also just started a new week, DOES have wicks to the upside and to the down side
and this is wrong, the weekly chart at the time of the screenshort just started , the candle should look exactly like the Daily candle at that time
[2017-10-22 05:15:14]
Not necessarily. Refer to help topic 12.4 about this:
http://www.sierrachart.com/index.php?page=doc/helpdetails12.html#h12.4
We cannot provide further help with this.
[2017-10-22 05:16:06]
Also the mistake you are making is you are comparing an Intraday chart to a Historical chart. These are totally different data types.
[2017-10-22 06:09:34]
N!co - Posts: 140
my apologies !!
the new weekly candle is starting one day later, my bad !!
i thought it was already sunday evening
sorry !
