Date/Time: Thu, 19 Sep 2024 22:02:02 +0000
teletrader
View Count: 4785
[2014-04-09 04:16:31] |
Yes, this is all correct.
[2014-04-24 11:00:32] |
ymlee - Posts: 23 |
Hi SC Team, Is Tele-Trader ready? |
[2014-05-16 08:40:14] |
AKR - Posts: 523 |
Any news on tele trader?
[2014-05-16 08:55:43] |
TeleTrader support from our side is ready. But the order form for it from TeleTrader is not yet.
[2014-05-27 15:48:53] |
AKR - Posts: 523 |
I see there is docu already to this. Do I understand right that - at least for now - TeleTr will not be available together with SC DF in one instance but to use TeleT I will have to install a second copy of SC, right? -- ah seems in screenshot both possibe, but I guess I can not have a trading service + SC DF + TeleTr ?
Date Time Of Last Edit: 2014-05-28 05:02:38
[2014-05-28 07:56:31] |
We can set up support for TeleTrader to be used as an alternative data feed with the trading service you are using. We need to know what the trading service is and what symbols. However, it would be difficult for us to set this up for the EUREX because that is mapped to the Sierra Chart data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-28 10:53:56] |
AKR - Posts: 523 |
well actually I do not want to use TeleT with a broker service. but what I would love to have is broker service (only futures) + SC DF + Teletrader in adition in one instance (without possibility to trade with the TeleT feed. Just to avoid a second installation. but probably that is not such a bad think as I consider it to be. |
[2014-05-28 16:35:54] |
For this you will need 2 installations of Sierra Chart.
[2014-05-30 10:47:07] |
User60579 - Posts: 41 |
I am a new user o Sierra Chart but I must say that I am impressed about the program and how you constantly develop it! I am allso very interested in the new Teletrader data feed. Is it already possible to start using it or does anyone now when? For those of you that have been in contact with Teletrader -do they have market internals for Frankfurt stock exchange? Have a great weekend everyone! In Sweden we have a fantastic summer day :) |
[2014-05-30 16:11:54] |
Sierra Chart does support TeleTrader at this time but we are waiting for the TeleTrader order form for the service. Here is our documentation page for TeleTrader: http://www.sierrachart.com/index.php?l=doc/TeleTrader.php We will have TeleTrader answer your questions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-30 21:17:47] |
TeleTrader Support - Posts: 4 |
Hi, In case Market Internals mean Advance Decline information we do support that. Not for whole markets, but for all members of specific indices. As for Frankfurt we support such market internals for DAX. More specific we support DAX Advance, DAX Advance Volume, DAX Advance/Decline Line, DAX Advance/Decline Momentum Volume Line, DAX Advance/Decline Momentum Volume Ratio, DAX Advance/Decline Ratio, DAX Advance/Decline Volume Line, DAX Advance/Decline Volume Ratio, DAX Decline, DAX Decline Volume, DAX Momentum Advance Volume, DAX Momentum Decline Volume. At the moment we wait for the final check of the implementation by our technical team. We want to make sure to deliver a high quality datafeed service and at the moment some final tweaks are done. thanks for your patience, your TeleTrader Support Team (support@teletrader.com) |
[2014-06-01 16:54:12] |
AKR - Posts: 523 |
Hi TeleT support, actually I am a bit disappointed you provide A/D lines for DAX only. It would be of MUCH more help if it was of total Xetra or Frankfurt. Is there any possibility you might provide this as well some time near? Rgrds |
