Date/Time: Thu, 16 Jan 2025 06:46:28 +0000
[User Discussion] - Trade Mgmt by Study - Volume Profile
View Count: 685
[2017-10-21 21:27:48] |
User104854 - Posts: 457 |
I use the trade mgmt by study to trail stops. Is it possible to use it with volume profile to trail valley lines as they occur? I've set everything up on a drawn profile with the study and it doesn't seem to be working. It seems like it should as the valleys are a subgraph and have values. Thanks.
[2017-10-22 00:23:53] |
No, this is not supported and this is not possible. It is possible to do this with custom development but we cannot provide any help with that. Other than refer you to this particular function: http://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html#scGetStudyPeakValleyLine We cannot provide any further help, and this is very advanced programming. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
