Date/Time: Thu, 16 Jan 2025 06:44:04 +0000
Spreadsheet Study
View Count: 845
[2017-10-20 20:15:51] |
infpz - Posts: 826 |
Can you direct me to documentation related to the regions where my outputs display? For example can I have Column 0 display in region 2 but Column P display in region 3?
[2017-10-22 02:08:35] |
This is not supported. The Spreadsheet Study can only display in one Chart Region. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-22 05:55:54] |
Sawtooth - Posts: 4153 |
A workaround is to add a 1-period SMA, 'Based On' the spreadsheet's subgraph (column). They you can display that column's values in any chart region.
