Date/Time: Sun, 24 Nov 2024 03:07:25 +0000
[User Discussion] - Transparent Fill Top & Bottom Shading Change
View Count: 1535
[2013-09-10 17:26:00] |
JayShea - Posts: 92 |
Hello I'm attaching a chart in which I use jsyd's excellent jdt MACD/Bollinger Bands/Heikan-ashi custom study. I've used a Transparent Fill Top & Bottom Shading inside the upper and lower Bollinger Bands for visuals. When the Bollinger Bands narrow and then widen again, I'd like to be able to change the fill color until the bands have widened and then the color reverts so that there are two colors. Is that possible? Thanks JD Date Time Of Last Edit: 2013-09-10 17:27:05
2013-09-10_BBMACD.png / V - Attached On 2013-09-10 17:22:20 UTC - Size: 113.99 KB - 512 views |
