Date/Time: Thu, 16 Jan 2025 07:01:12 +0000
chart customization
View Count: 1186
[2017-10-20 19:06:07] |
User780238 - Posts: 45 |
1. What settings do I change allowing me to move a chart up or down with the Y-Axix prices staying still? Scrolling my mouse allows the Y-Axis price to go up and down and moves the chart and candlesticks with it. I'd like to move the candlesticks/chart up or down (scrunch or expand) without having the Y-Axis prices move. 2. Also, I want to change the triangle direction, size of dots and the colors of candlesticks within my chart books created that use Rob Hoffman's CS MFT setups. Is there a way to globally change all of the charts I've created or do I have to change each one individually? Must I duplicate one and redo all the rest for needed time & instrument? Thanks |
[2017-10-22 08:03:46] |
Update Sierra Chart to the current version following the instructions here: Software Download: Fast Update Log into this Support Board with Help >> Support Board. 1. Refer to: Chart Scale and Scale Adjusting: Interactive Scaling 2. In general refer to: Chart Studies: Subgraphs Tab Graphics Settings Is there a way to globally change all of the charts I've created or do I have to change each one individually? Must I duplicate one and redo all the rest for needed time & instrument? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
