Date/Time: Thu, 16 Jan 2025 07:04:10 +0000
Study Display Question
View Count: 777
[2017-10-20 15:56:36] |
Xfanman1 - Posts: 320 |
I'm using the Study Subgraph Subtract/Difference and the Study Subgraph in Ticks to display the Ticks between one study and current price. I would like it to display on the current candle and ONLY the current candle instead of painting on every candle displayed on the chart. (See chart) Is this possible with a different setting configuration or with another study that I've missed? In addition, I'd prefer the dollar amount represented by the ticks to display but that's secondary to my first question. Thanks much....Scott Date Time Of Last Edit: 2017-10-20 15:57:05
ExampleTickCount.PNG / V - Attached On 2017-10-20 15:56:28 UTC - Size: 108.61 KB - 282 views |
[2017-10-20 18:29:46] |
The only way to do this is to use the Draw Style: Chart Studies: Line at Last Bar to Edge (ACSIL: DRAWSTYLE_LINE_AT_LAST_BAR_TO_EDGE) (Line at Last Bar to Edge) We can add input to the Study Subgraph in Ticks study to multiply it by the Currency Value per Tick. We will do that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-20 19:12:55] |
Instead we need to add a new study for this and it will be called Study Subgraph as Currency Value.
