Date/Time: Thu, 16 Jan 2025 07:00:21 +0000
Chart order fills arrows misplaced
View Count: 916
[2017-10-20 15:40:30] |
warbuf - Posts: 1 |
I'm getting my filled orders arrows misplaced in the chart as you can see attached: http://www.sierrachart.com/image.php?Image=1508513906776.png |
[2017-10-20 18:51:05] |
Most likely this is due to an incorrect timestamp with the order fills and it is explained here: Chart Trading and the Chart DOM: Misaligned Order Fill Markers on Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
