Date/Time: Sun, 24 Nov 2024 07:00:32 +0000
[User Discussion] - Spreadsheet reversals
View Count: 1607
[2013-09-10 17:13:45]
toews&kane - Posts: 209
I can't wrap my head around reversals and the settings that are available to support this in the spreadsheet study settings.
What I want to do is if I am already in a long, if there's a short signal then reverse and go short.
Do I need to put a condition in buy exit for example if I am already long for if sell entry is true?
[2013-09-10 18:03:31]
The Reversal documentation is here:
http://www.sierrachart.com/index.php?l=doc/doc_AutoTradeManagment.php#SupportReversals
You will not use Buy/Sell Exit for this.
[2013-10-03 18:07:06]
If I have signal once per bar turned on say a sell exit also equals a buy entry, if the sell exit gets triggered first, the buy entry would not get triggered.
how do I get it to reverse instead?
