Date/Time: Thu, 16 Jan 2025 06:56:18 +0000
All charts open on 30 min
View Count: 749
[2017-10-20 07:25:46] |
User135248 - Posts: 1 |
Hi since last update all my intraday charts open at 30 min when I restart SC instead of Range bars? How can I solve that? Thanks for the help |
[2017-10-20 07:36:06] |
This problem has been resolved. Update Sierra Chart with Help >> Download Current Version. After the update you need to change the chart Bar Period Type to Range Per Bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
