Date/Time: Thu, 16 Jan 2025 06:57:31 +0000
VWAP
View Count: 1545
[2017-10-20 06:48:53]
User464702 - Posts: 18
I cant figure out why my vwap starts on the night session.
Any help would be great
imagevwap b.png / V - Attached On 2017-10-20 06:43:20 UTC - Size: 52.95 KB - 315 views
imagevwap a.png / V - Attached On 2017-10-20 06:45:42 UTC - Size: 139.35 KB - 321 views
[2017-10-20 18:04:09]
This is because you are using Evening Session Times and that Evening Start Time is considered the start of the trading day. You need to disable that. Refer to:
Chart Session Times
[2017-10-21 03:25:40]
Why would the vwap start in the evening session? Seems a bit backwards
[2017-10-21 03:44:34]
I have made reversed the night and day session and it appears to have worked, except for the 20th?
imagevwap c.png / V - Attached On 2017-10-21 03:44:25 UTC - Size: 98.73 KB - 322 views
[2017-10-22 05:17:44]
Refer to:
Chart Session Times: Understanding Trading Day Dates Based on Session Times
In regards to post #4, we do not understand this. Also, we will only accept chart images that follow these specifications:
In this case any other will be disregarded.
