Date/Time: Thu, 16 Jan 2025 07:00:18 +0000
how to count the number of o or xs in a column
View Count: 772
[2017-10-20 03:37:22] |
madra - Posts: 109 |
Hello, Thanks for the speedy help in my last request I have tried to use the chart calculator to count the number of xs or os in a column in POINT AND FIGURE CHARTS is there a tool for this or some adjustment to the chart calculator that will work. Thank you for your continued help all the best |
[2017-10-20 09:39:33] |
We will add a new study named Point and Figure Box Count, to the next version.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-20 09:39:48
