Date/Time: Thu, 16 Jan 2025 07:02:50 +0000
awl - trend lines 45 degree line copied to next chart
View Count: 1225
[2017-10-19 16:25:11]
madra - Posts: 109
hello,
I use the AWL when I draw lines e.g support and resistance or 45 degree on a symbol works very well But when I click on the next symbol the lines for the previous symbol are on the chart.
So is there a way to have the drawings for each symbol particular to that chart.
Thank you
[2017-10-19 18:29:28]
Yes, refer to this section here for this:
https://www.sierrachart.com/index.php?page=doc/Tools.html#ShowingDrawingsforDifferentSymbols
