Date/Time: Thu, 16 Jan 2025 06:41:45 +0000
Crosshair Pip Range
View Count: 1779
[2017-10-19 14:33:33] |
User369868 - Posts: 6 |
I am switching to Sierra Chart from MT4. One feature in MT4 that I use constantly is the Crosshair--Left click drag which shows the pip range of drag. I suspect that Sierra Chart has a similar feature but I have not found it. How can I use the cursor/crosshair to drag a range of bars to show the pips in that range?
[2017-10-19 17:33:36] |
This is accomplished with the Chart Calculator tool: Chart Drawing Tools: Chart Calculator Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
