Date/Time: Tue, 08 Sep 2026 11:48:56 +0000
[User Discussion] - Stop trading after a lost
View Count: 1878
| [2017-10-19 12:37:14] |
| User29926 - Posts: 92 |
I remember seeing a post some time ago with code to stop trading after a lost. Then start trading after a number of bars had passed. But I cant find it anymore thru the search feature. I wanted to try and convert that code to stop trading until a indicator value changes, then allow trading again. Does anyone have any sample code they could supply or just point me to the post regarding how to stop trading after a lost and I will attempt to modify that to what I need. This is my current code attempt at stopping trading until an indicator value changes. It stops trading with a "1", but I cant figure out how to get it to switch back and stay at "0" to allow trading again. =IF( AND( $H$90 =0,$J$44 <0, $H$56 = ID17.SG8@8) ,1,IF( OR( $H$90= 1,$H$56 <> ID17.SG8@8), 0 , IF(ISBLANK($H$98),0 ,$H$98) )) Thanks Date Time Of Last Edit: 2017-10-19 13:12:56
| [2017-10-21 00:49:07] |
I guess no one has ever wanted to stop trading after a lost and start back after a condition is met. Interesting. Date Time Of Last Edit: 2017-10-21 00:49:30
| [2017-10-21 01:19:15] |
| Sawtooth - Posts: 4350 |
You could use this example as a starting point: http://www.sawtoothtrade.com/example-1.html Edit the last part of the cell P3 example formula with your resetting condition. |
| [2017-10-21 22:50:43] |
Thanks tomgilb for the code block. I`m still trying to get it modified correctly to work.. O cell code: =IF(QO3>QO4,TRUE,IF(OR(QQ3>QQ4,INT(A3)>INT(A4)),FALSE,O4)) P cell code: =IF(AND(O3,O4=FALSE),1,IF(AND(QO3,QO3>QO4),P4+1,IF($H$90= 1,0,P4))) $H$90= 1 is the switch that should set it zero Currently the P cell is stuck on True even while the O cell is still False $J$28 cell code: =IF($J35=0, 0 ,IF ($P$3 = 1, 1,0) ) Date Time Of Last Edit: 2017-10-21 23:02:06
| [2017-10-24 02:17:52] |
Update: I thought I had it working correctly, but started having issues with it flipping back to True thus turning off the trading even after the indicator value reset it. Current O3 cell code: =IF(OY3>OY4,TRUE,IF(OR(PA3>PA4,$H$90= 1),FALSE,O4)) Current P3 Cell code: =IF(AND(O3,O4=FALSE),1,IF(AND(O3,OY3>OY4),P4+1,IF(AND(O3,O4),P4,0))) Current J28 code: =$P$3 tomgilb any idea why the $P$3 keeps going back to True after the indicator value resets it? Causing no more trading after the 1 lost is posted? $H$90 is normally False, until multiple indicators value sets it to True. When that happens I need P3 to reset to false "0" and allow trading again. $H$90 will go back to False "0" when the multiple indicators values are back in alignment again. But I need the P3 to stay False when $H$90 goes back to False, so trading can continue until another lost happens. Date Time Of Last Edit: 2017-10-24 04:30:49
| [2017-10-26 00:57:34] |
This must be a hard formula to get working correctly. Over a 114 views, but no one has been capable of solving it yet. Date Time Of Last Edit: 2017-10-26 00:59:31
| [2017-10-26 01:49:15] |
It's not that the formula would be difficult. It's that it's not possible to discern from the info you've provided. There could be no straight-forward answer; it looks to be more complex than can be quickly solved. I would not use a lock TRUE in H90. Instead, I'd use a Formula Column to set a persistent TRUE with one set of conditions that would release with another set of conditions. As I've said, using a lock TRUE is only needed in rare occasions, and is often tricky to configure. Date Time Of Last Edit: 2017-10-26 05:45:31
| [2017-10-26 02:59:17] |
Ok, I will try to be more concise about what is needed and why I use a locking/persistant cell. (1) When there is a losing trade, I need to disable auto trading J28 with a "1". (2) When the $H$90 cell value changes from a "0" to a "1" , I need to re-enable auto trading J28 with a "0". (3) When the $H$90 cell value switches back to a "0". I need the J28 to stay a "0" even tho there is still a losing trade on the board. I wouldn't say the $H$90 cell is a locking cell, its more of a persistent value. Since the locking cell ability only allows one parameter to unlock it. I use the cell $H$90, to condense about 8 different chart indicators, cell values and various price conditions. I reference the chart indicators directly ie: ID17.SG8@3, instead of a direct cell reference. This way I can add or remove indicators without having to worry about cell changes. When all the conditions are true the $H$90 cell is set to "0". The $H$90 cell is reset by a change in anyone of the conditions that set it. The $H$90 cell (Long trades)and another cell $H$91 (Short trades)controls 96% of the decisions to enter a trade or not. By using the two cells, my K3 and M3 cell are very clean and only reference 3 other cells and has no long complicated formulas in it. Date Time Of Last Edit: 2017-10-26 03:09:11
| [2017-10-27 15:08:46] |
Update: I believe I have achieved what I was trying to accomplish. So far the formula is holding up thru a 60 day replay test. =IF(AND($J$44 < 0, ID22.SG1@3 > ID22.SG1@4),1, IF( $H$90 ,0 ,IF(ISBLANK($J$28),0 ,$J$28) )) Thanks tomgilb for the link to the code on your website that informed me that there was a losing trades study in SC. |
