Date/Time: Thu, 16 Jan 2025 06:42:08 +0000
After updating to version 1624 RangeBars gone
View Count: 772
[2017-10-19 09:41:52] |
Autotrade8 - Posts: 26 |
Hello, I discovered a very strange behavior this morning after I update SC to version 1624. I am using a RangeBar chart. After closing the chartbook and reopen again the chart is now a normal minute Bar! I tried several times. Than I changed the chart temporarily in Renko for testing. After I closed the chartbook and reopen again the chart is still Renko! So, it looks that if you are using RangeBars your chart will automatically changed to a minute Bar after you close your chartbook or close SC and reopen again. Please, let me know. Johan |
[2017-10-19 18:22:21] |
We are solving this now.
