Date/Time: Thu, 16 Jan 2025 06:54:41 +0000
single drawing mode
View Count: 636
[2017-10-19 07:42:27] |
User884550 - Posts: 149 |
is it possible to arrange that after 1 drawing it changes to cursor again
[2017-10-19 10:08:13] |
There is a setting for this and it is documented here: Chart Drawing Tools: General Tool Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
