Date/Time: Thu, 16 Jan 2025 06:53:27 +0000
Study or Spreadsheet Function to Identify Max Bid and Ask Level Within Numbers Bar
View Count: 789
[2017-10-19 00:35:06] |
absorrel4 - Posts: 97 |
Please see the attached exhibit. Is there a study or spreadsheet function whereby I can have Sierra Chart identify the absolute maximum Bid and Ask within any given bar. I am using the Numbers Bar and would like the maximum bid/ask levels identified within any given numbers bar. As shown in the exhibit, the very last Numbers Bar shows a maximum of 22 Bid and 163 Ask. I would then like to be able to identify the absolute max Bid/Ask numbers within each bar and then create an alarm if one (or both) of those bid/ask max numbers exceeded my desired threshold. Thank you...
Max Bid and Ask Highlighted.jpg / V - Attached On 2017-10-19 00:34:14 UTC - Size: 408.81 KB - 320 views |
[2017-10-19 19:57:48] |
Have a look at this study: Volume at Price Threshold Alert V2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
