Date/Time: Thu, 16 Jan 2025 06:52:40 +0000
Last Price Marker
View Count: 1616
[2017-10-18 17:46:46] |
User301798 - Posts: 9 |
Is there an easy way to place a "<" next to the last price of the current bar on a Point and figure chart?
[2017-10-18 17:59:00] |
No, but you can set the Graph Draw Type to OHLC Bar to see where the last trade price is: Graph Draw Types Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-19 17:15:29] |
Then I wouldn't have a Point & Figure chart... Thank you for the prompt reply
[2017-10-19 17:58:00] |
As an alternative use the Current Price Line study: Current Price Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-19 18:04:23] |
I saw that but don't like the line going all the way across my chart- Would it be an easy Modification to just make it plot "<" after the last price? (I cannot find that study in the source folder)
[2017-10-20 18:13:30] |
There are various Inputs this study has, to control whether it draws to the left or right, and how many bars. Here is the documentation for the study: Current Price Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
