Date/Time: Thu, 16 Jan 2025 06:10:27 +0000
"Copy Chart Drawings from" feature
View Count: 655
[2017-10-18 14:13:17] |
User56866 - Posts: 28 |
Hi I remember when I used the option to Show Chart Drawings drawn on another chart those drawings would not be editable on the chart I was choosing to show them on. They now seem to be editable even from the chart they were not drawn on. I see this is a recent change. Is there an option to disable this to avoid them being accidentally changed? In short, can I disable the ability to modify chart drawings that are copied from another chart, on the destination chart? Thank you Date Time Of Last Edit: 2017-10-18 14:15:57
[2017-10-18 17:23:46] |
This can be disabled. Refer to: Chart Drawing Tools: Modifying and Deleting Drawing Copied to Other Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
