Date/Time: Thu, 16 Jan 2025 06:55:31 +0000
Daily chart OHLC value times
View Count: 882
[2017-10-18 13:26:11] |
Asif_Bacchus - Posts: 4 |
I have changed the Global Symbol Settings > Intraday session times for symbols I trade so that the session lines on my charts display as I want them. For example, futures currencies such as British Pound or Canadian Dollar default to starting at 00:00:00 and ending at 23:59:59 but they really should be aligned with the CME actual times of 17:00:00-16:00:00 (Central Time). I understand this is a setting from my data provider and not SC in particular. However, now that I have changed the times and my intraday sessions are correct, I am wondering about my daily charts. It seems that the closing values on my intraday charts and my daily charts are not the same. Do the daily charts still work off the default session times? Can I somehow automatically make daily charts be constructed using my times (i.e. 17:00:00 Central Time close)? Thanks.
[2017-10-18 18:08:20] |
All of this is explained in detail here: Historical Chart Prices In particular you need to understand the "Settlement" price of daily chart bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
