Date/Time: Thu, 16 Jan 2025 06:58:23 +0000
Change CQG default to WebAPI instead of FIX?
View Count: 670
[2017-10-18 13:12:14]
Asif_Bacchus - Posts: 4
I am using CQG data through AMP futures with SC. Every time I start the program, it tries to connect via CQG FIX (which will NOT connect) and I have to manually switch it to CQG WebAPI then everything works perfectly. Is there a way to have it remember to just use WebAPI? Thanks.
[2017-10-18 17:52:15]
We have now corrected this for your account.
