Date/Time: Thu, 16 Jan 2025 06:08:00 +0000
Candles and OHLC line
View Count: 836
[2017-10-17 20:59:59] |
bala - Posts: 74 |
I can set chart settings for prices to be in candles or line on OHLC avg. Can I have both? ( that is have prices in candles displayed AND have a price line in addition) . I am currently using a SMA with period of 1. Thanks, Bala |
[2017-10-17 22:34:09] |
No. You would need to use a study for this like you are. You could do it the way you are or use the Overlay (Single Line) study.
