Date/Time: Thu, 16 Jan 2025 07:01:19 +0000
ACSIL: My s_UseTool Lines are drawing on chart during historical downloading...
View Count: 820
[2017-10-17 17:07:45] |
John Carey - Posts: 5 |
My s_UseTool Lines are drawing on chart during historical downloading, therefore drawing in wrong places...especially when the studies are already on the chart and I switch symbols or whatever. I thought this would be an easy job for: if (sc.DownloadingHistoricalData == 1)
{ return; } ...and it does fix the problem. However, now they don't plot at all, when before they would plot all over. Thoughts? Thanks. |
[2017-10-18 16:49:48] |
Hi guys, is there any idea on this one? Is there enough info here to get an answer? Many thanks for any input.
[2017-10-18 17:04:29] |
Not really. We do not provide programming help. You need to look at your code and find out why the chart drawings are not being added. Apparently you are not making a call to sc.UseTool. There is no way that we could know this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-18 17:05:57
[2017-10-19 07:01:08] |
Thanks for the info, support. Eventually I tried checking sc.ChartIsDownloadingHistoricalData , which is worded extremely similarly sc.DownloadingHistoricalData but seems to have worked a bit better for my situation. I hope this may help someone in the future.
