Date/Time: Thu, 16 Jan 2025 06:10:35 +0000
Questions related to Clock
View Count: 902
[2017-10-17 16:11:37] |
ticinotrader - Posts: 397 |
Dear Support, Can you please give some advice regarding the following two questions? 1. Is it possible to set up the Clock study to show the time from the chart what the Clock is attached to, instead of the system time? This would be especially useful/needed when using the study during replay. During replay, the system/local clock is displayed. 2. Would it be possible to display the clock in the Control Bar similar to the status bar? This would allow displaying the time on DOM windows very easily. Again it would be great to be able to select between local/system time vs DOM's actual time (the later would be useful for DOM replay). Thank you. |
[2017-10-17 17:03:25] |
1. Do you mean the last trade price? Yes we can do this. We will go ahead and make that the default. Although hopefully it will not be misleading when a chart is replaying and someone is expecting to see the current time. 2. No, this is not supported. It is not a task we would take. You can just add the Clock study to the Trading DOM. Refer to: Chart Trading and the Chart DOM: Adding Studies on a Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-17 18:42:31] |
Regarding #1: Yes, time of the last trade price. Thanks! |
