Date/Time: Thu, 16 Jan 2025 06:07:17 +0000
dvp
View Count: 825
[2017-10-17 08:29:04] |
User882442 - Posts: 17 |
hello, i have problem with DVP. in one computer i have edit it without any exception. i can catch it and extend it to area what i want. in secont computer i dont do this and i dont know why. look at screens |
sierra.jpg / V - Attached On 2017-10-17 08:26:24 UTC - Size: 145.87 KB - 267 views Zrzut ekranu 2017-10-17 09.28.40.png / V - Attached On 2017-10-17 08:26:50 UTC - Size: 82.69 KB - 273 views |
[2017-10-17 17:30:07] |
Here are the instructions to modify a Volume Profile that has been manually drawn: Volume By Price Study: Modifying Manually Drawn Volume Profile If you cannot modify it, then just remove it from the chart through Analysis >> Studies and draw it again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
