Date/Time: Thu, 16 Jan 2025 06:06:18 +0000
Adding a way to be able to add limit orders between best bid/ask on the DOM ?
View Count: 905
[2017-10-17 07:47:07]
gomifromparis - Posts: 244
It seems that as of today, the DOM decides that an order is a stop or a limit depending on the last trade.
This implies that one side is not able to enter limit orders between the best bid/ask : they will be considered stop orders.
Would it be possible to add an option that the decision is made on the current best bid/best ask (if avail), not the value of the last trade.
Here's a pic of BitMex showing the idea. It's very imporant on crypto exchanges to be able to enter with limit orders due to the fee structure (taker/maker of liquidity), but I can't enter the limit orders on one side (using the DOM)
imagebitmexDOM.png / V - Attached On 2017-10-17 07:46:10 UTC - Size: 22.44 KB - 290 views
[2017-10-17 09:42:01]
We know how to solve this. We will work on that.
You can also adjust the General Settings >> Chart DOM Settings to use right-click operations to submit the different order types.
[2017-10-17 09:55:00]
OK, however all the orders settings with right click / left click depend if the price is above/below Last.
If we have a 5 point spread and Last oscillates between best bid/best ask, you can't really settle on right or left clicking in the middle of the 5 point spread.
[2017-10-17 16:33:03]
But what you can do in the settings is use the same Order Type whether the order price is above or below the last trade price.
[2017-10-17 16:44:05]
Y OK, forcing only limit orders everywhere
