Date/Time: Thu, 16 Jan 2025 06:04:38 +0000
Slow chartbook tab switching
View Count: 818
[2017-10-17 06:20:55] |
User99567 - Posts: 9 |
Hello, i am experiencing slow reactions in switching the tabs in sierra chart. I have checked the memory it is using and this is only 2 GB. At first everything was fine, but it has been slowing down. Anyone has a solution for this problem? Thanks in advance! |
[2017-10-17 07:07:37] |
In general refer to help topic 30 for solutions: Http://www.sierrachart.com/index.php?page=doc/helpdetails30.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
