Date/Time: Thu, 16 Jan 2025 05:56:10 +0000
Can not start Sierra Chart
View Count: 831
[2017-10-17 03:06:18]
brando - Posts: 14
Sierra Chart will not load and I get the following message--Program can't start because LIBEAY32.dll is missing from your computer. All other programs and files are working.
[2017-10-17 05:17:35]
You are running an older version of Sierra Chart.
Install Sierra Chart again using this old installer:
https://www.sierrachart.com/downloads/SierraChartSetup.exe
Do you still use Old Spreadsheets? Otherwise, you need to update the current version of Sierra Chart.
