Date/Time: Thu, 16 Jan 2025 06:02:02 +0000
issue with Study Subgraph Add, Subtract, Divide, etc with Percentage Price Oscillator
View Count: 943
[2017-10-16 20:31:50] |
User686802 - Posts: 69 |
Hi, i want to take the Main Graph price and do Study Subgraph Add, Subtract, Divide etc and then get Percentage Price Osiilator graph of the modified Main graph price, but somehow, the Percentage Price Oscilator Study ignores any INPUT that is NOT the Main graph price.
[2017-10-17 05:21:53] |
The problem is that the Percentage Price Oscillator study is designed to be based only on the Last/Close Subgraph which does not exist with these other arithmetic studies you are using. We will see about adding an Input Data input to that study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-17 05:22:30
[2017-10-17 12:47:50] |
OK, also can you make the Percent value format for Percentage Price Oscillator work like the Percent Since Last Open / Close to get the % symbol with the default 2 decimal places?
